Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM100 Fan noise
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="guitarguy510" data-source="post: 2015" data-attributes="member: 44"><p>The fan only makes noise because it's running. A lot of computer fans do the same thing. They are working pretty hard to keep those power tubes cool, it's pretty normal AFAIK. It never bothered me too much, let me know the amp was alive (breathing, if you will lol) plus it helped remind me to turn it onto standby and then I never forgot to make sure it was turned off! <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /> Basically it is normal, and I wouldn't suggest swapping out the fan as they chose the one they did for a reason. Just my .02's sir! <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p></blockquote><p></p>
[QUOTE="guitarguy510, post: 2015, member: 44"] The fan only makes noise because it's running. A lot of computer fans do the same thing. They are working pretty hard to keep those power tubes cool, it's pretty normal AFAIK. It never bothered me too much, let me know the amp was alive (breathing, if you will lol) plus it helped remind me to turn it onto standby and then I never forgot to make sure it was turned off! :) Basically it is normal, and I wouldn't suggest swapping out the fan as they chose the one they did for a reason. Just my .02's sir! :) [/QUOTE]
Verification
Post reply
Modular Amps
RM100 Fan noise
