Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM20 Volume Fluctuations
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Jaded Faith" data-source="post: 139739" data-attributes="member: 1068"><p>If you are only having an issue when certain modules are involved and not others, that turns attention to the modules themselves and not your amp.</p><p></p><p>Read the info in this post: <a href="http://mtsforum.grailtone.com/viewtopic.php?t=19525" target="_blank">http://mtsforum.grailtone.com/viewtopic.php?t=19525</a></p><p></p><p>Look at the tubes in the offending modules. I often see donors here where one tube was damaged by using it in V2 and it not being able to handle the CF circuit. It's not a complete failure and all that that needs to be done is a simple swap of V1 and V2. As a matter of fact, I saw 2 modules this week with this very issue.</p><p></p><p>Hope this helps. If you still have problems, please email for a prompt response.</p></blockquote><p></p>
[QUOTE="Jaded Faith, post: 139739, member: 1068"] If you are only having an issue when certain modules are involved and not others, that turns attention to the modules themselves and not your amp. Read the info in this post: [url]http://mtsforum.grailtone.com/viewtopic.php?t=19525[/url] Look at the tubes in the offending modules. I often see donors here where one tube was damaged by using it in V2 and it not being able to handle the CF circuit. It's not a complete failure and all that that needs to be done is a simple swap of V1 and V2. As a matter of fact, I saw 2 modules this week with this very issue. Hope this helps. If you still have problems, please email for a prompt response. [/QUOTE]
Verification
Post reply
Modular Amps
