Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM4 Multiple Outputs
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="JMMP" data-source="post: 153272" data-attributes="member: 3625"><p>An update in case anyone else is looking for the answer: It works just fine. I took the pre loop output of the RM4 straight into my mixer, and the post effects loop outputs into the L/R inputs of the Eventide (just for this test, in the future it will be one input per effect unit, with a Y cable) and the Eventide's outputs into the mixer, and from the mixer to a stereo power amp and stereo cab. The eventide received plenty of signal (actually had to pad the input by 6dB) and it all sounded great!</p></blockquote><p></p>
[QUOTE="JMMP, post: 153272, member: 3625"] An update in case anyone else is looking for the answer: It works just fine. I took the pre loop output of the RM4 straight into my mixer, and the post effects loop outputs into the L/R inputs of the Eventide (just for this test, in the future it will be one input per effect unit, with a Y cable) and the Eventide's outputs into the mixer, and from the mixer to a stereo power amp and stereo cab. The eventide received plenty of signal (actually had to pad the input by 6dB) and it all sounded great! [/QUOTE]
Verification
Post reply
Modular Amps
