Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RM4 Problem is back
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="nomad100" data-source="post: 84990" data-attributes="member: 1490"><p>I had this problem with my Mesa nomad head, turned out to be an issue with the switching matrix. Clean channel would go from awesome to crap with a fuzzy sound. Turn it off then back on and it would be fine. Had it repaired it worked for a while then broke again. Then again maybe chNhinf the relays didn't fix it and I just didn't screw up for a while after the repair. Not like j had much time to play at that point in my life.</p></blockquote><p></p>
[QUOTE="nomad100, post: 84990, member: 1490"] I had this problem with my Mesa nomad head, turned out to be an issue with the switching matrix. Clean channel would go from awesome to crap with a fuzzy sound. Turn it off then back on and it would be fine. Had it repaired it worked for a while then broke again. Then again maybe chNhinf the relays didn't fix it and I just didn't screw up for a while after the repair. Not like j had much time to play at that point in my life. [/QUOTE]
Verification
Post reply
Modular Amps
RM4 Problem is back
