Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
DIY
RT2/50 mods..
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="m0jo" data-source="post: 91269" data-attributes="member: 1664"><p>SE = Single Ended, as opposed to Push-pull.</p><p></p><p>If I say it right, push pull means one tube will work one phase of the signal, while the other tube in the pair does the other phase, so basically pushing and pulling the signal.</p><p>Single ended is where the signal is only being pushed one side, so you can use one tube for this (whereas push-pull requires 2 tubes to accomodate the 2 functions).</p><p></p><p>Am I getting this right guys?</p></blockquote><p></p>
[QUOTE="m0jo, post: 91269, member: 1664"] SE = Single Ended, as opposed to Push-pull. If I say it right, push pull means one tube will work one phase of the signal, while the other tube in the pair does the other phase, so basically pushing and pulling the signal. Single ended is where the signal is only being pushed one side, so you can use one tube for this (whereas push-pull requires 2 tubes to accomodate the 2 functions). Am I getting this right guys? [/QUOTE]
Verification
Post reply
Modular Amps
DIY
RT2/50 mods..
