Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
RT2/50 Questions
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="s.fitzsimmons" data-source="post: 99388" data-attributes="member: 2908"><p>New here and considering running a RT2/50 with my 11R and wondering if you guys would be able to help me out. Wasn't able to figure the following out from the manual:</p><p></p><p>* Since it's stereo, do you need separate loads attached to channel 1 & 2 regardless of which mode you're using??</p><p></p><p>* In switching mode you can run Channel 1 or 2, but can you run Channel 1 <strong><u>and</u></strong> 2?</p><p></p><p>* I'd be re wiring my 4x12 to separate jacks to accommodate the individual loads. Anyone do this and not happy with the sound?</p><p></p><p>* Anyone using a more complicated midi switch like the Behringer FCB1010 or Roland FC300 with a preamp and RT2/50 with any luck?</p><p></p><p>I love how the manual tells you that the main output is currently connected to your internal speakers. They really phoned it in on this one!</p><p></p><p>Thanks in advance for the responses!</p></blockquote><p></p>
[QUOTE="s.fitzsimmons, post: 99388, member: 2908"] New here and considering running a RT2/50 with my 11R and wondering if you guys would be able to help me out. Wasn't able to figure the following out from the manual: * Since it's stereo, do you need separate loads attached to channel 1 & 2 regardless of which mode you're using?? * In switching mode you can run Channel 1 or 2, but can you run Channel 1 [b][u]and[/u][/b] 2? * I'd be re wiring my 4x12 to separate jacks to accommodate the individual loads. Anyone do this and not happy with the sound? * Anyone using a more complicated midi switch like the Behringer FCB1010 or Roland FC300 with a preamp and RT2/50 with any luck? I love how the manual tells you that the main output is currently connected to your internal speakers. They really phoned it in on this one! Thanks in advance for the responses! [/QUOTE]
Verification
Post reply
Modular Amps
RT2/50 Questions
