Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
Serious volume question???
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="trendkill1168" data-source="post: 30661" data-attributes="member: 11"><p>Also...what ohm value is your cab? Randall shows these heads running at 500 watts at 2 ohms, 400 watts at 4 ohms, & 280 watts at 8 ohms. You might not be running at full power depending on how many ohms your cab is. If it's 16 ohms then you are running even less than 280 watts. Just a suggestion I thought I might mention.</p></blockquote><p></p>
[QUOTE="trendkill1168, post: 30661, member: 11"] Also...what ohm value is your cab? Randall shows these heads running at 500 watts at 2 ohms, 400 watts at 4 ohms, & 280 watts at 8 ohms. You might not be running at full power depending on how many ohms your cab is. If it's 16 ohms then you are running even less than 280 watts. Just a suggestion I thought I might mention. [/QUOTE]
Verification
Post reply
Off Topic
