Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Gigmods Module Mods
Soldering Rig
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="kc2eeb" data-source="post: 47039" data-attributes="member: 811"><p>Good choice!</p><p> Remember to use 60/40 ROSEN core (NOT Acid core) solder.</p><p>If you want to clean up the flux residue, use alcohol.</p><p>The trick is to use enough heat but not so much that you burn up the board</p><p>or traces. </p><p>Practice on a defective or broken PC board from a discarded electronic device. When you can remove and re-solder a component on the board</p><p>without damaging or lifting the conductive trace, you're getting there.</p><p>Try and get some desoldering braid and a solder sucker.</p><p>Good Luck!</p><p>Pat L.</p></blockquote><p></p>
[QUOTE="kc2eeb, post: 47039, member: 811"] Good choice! Remember to use 60/40 ROSEN core (NOT Acid core) solder. If you want to clean up the flux residue, use alcohol. The trick is to use enough heat but not so much that you burn up the board or traces. Practice on a defective or broken PC board from a discarded electronic device. When you can remove and re-solder a component on the board without damaging or lifting the conductive trace, you're getting there. Try and get some desoldering braid and a solder sucker. Good Luck! Pat L. [/QUOTE]
Verification
Post reply
Modular Amps
Gigmods Module Mods
Soldering Rig
