Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Stereo Rig set up Assistance
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BrodDalton" data-source="post: 161331" data-attributes="member: 4070"><p>Ned,</p><p>A bit ironic that you mention the Eventide H9...!!!! Simply because I too have an H9. When I implemented it into my effects chain, set up in a stereo cable routing config: Using the H9 setting interface to set the patch's preferred routing, only then did i realize it was not cabled properly and no matter how i ran my cables or set the H9's settings, I could not get it the H9 to split the output without sounding like crap or stepping all over other effects. However Using the H9 in my wet/dry set up: I'd plug in the H9 to the Dry side and the out 2 to the wet side set the individual patch routing config to Wet/Dry and it was total sweetness!!!! I especially liked the way the "Crystals" patch sounded in a wet/dry set up. that added a super cool ambient swell that came out of the wet cabs, albeit a totally useless patch, other than just noodling around or using it as a layered effect in a recording mix.</p><p></p><p>-And right down the rabbit hole I am !!!!!!</p></blockquote><p></p>
[QUOTE="BrodDalton, post: 161331, member: 4070"] Ned, A bit ironic that you mention the Eventide H9...!!!! Simply because I too have an H9. When I implemented it into my effects chain, set up in a stereo cable routing config: Using the H9 setting interface to set the patch's preferred routing, only then did i realize it was not cabled properly and no matter how i ran my cables or set the H9's settings, I could not get it the H9 to split the output without sounding like crap or stepping all over other effects. However Using the H9 in my wet/dry set up: I'd plug in the H9 to the Dry side and the out 2 to the wet side set the individual patch routing config to Wet/Dry and it was total sweetness!!!! I especially liked the way the "Crystals" patch sounded in a wet/dry set up. that added a super cool ambient swell that came out of the wet cabs, albeit a totally useless patch, other than just noodling around or using it as a layered effect in a recording mix. -And right down the rabbit hole I am !!!!!! [/QUOTE]
Verification
Post reply
Modular Amps
