Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Suitable FX processor
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="nitrous12" data-source="post: 134575" data-attributes="member: 3312"><p>I am currently using an HD500 in 4CM. Effects are pretty good, but I will qualify that I am not an effects power user so my opinion on the quality is...well just an opinion.</p><p></p><p>Its a great unit though and I can do a lot with it. Plus some of the models are actually pretty good. I have dialed in some really good mid and high gain tones as well as some clean tones that aren't too bad.</p><p>I think used you can find them in the $350 range.</p><p>What is nice about them is if you do find some good modeling patches you can add a lot of different sounds between the amps preamp modules and the modeling as from one patch to the next you can either use the HD500 preamp or that of the Randall or Egnater amp you have.</p><p>And should your amp go down you still have a functioning preamp and FX unit that can go right to the board.</p><p></p><p>Same can be said for the GSP 1101. I haven't used it with my MOD50, but I did have one a few years ago and it worked just as well. Separate rack mount unit and floor board though where the HD500 is all in one.</p></blockquote><p></p>
[QUOTE="nitrous12, post: 134575, member: 3312"] I am currently using an HD500 in 4CM. Effects are pretty good, but I will qualify that I am not an effects power user so my opinion on the quality is...well just an opinion. Its a great unit though and I can do a lot with it. Plus some of the models are actually pretty good. I have dialed in some really good mid and high gain tones as well as some clean tones that aren't too bad. I think used you can find them in the $350 range. What is nice about them is if you do find some good modeling patches you can add a lot of different sounds between the amps preamp modules and the modeling as from one patch to the next you can either use the HD500 preamp or that of the Randall or Egnater amp you have. And should your amp go down you still have a functioning preamp and FX unit that can go right to the board. Same can be said for the GSP 1101. I haven't used it with my MOD50, but I did have one a few years ago and it worked just as well. Separate rack mount unit and floor board though where the HD500 is all in one. [/QUOTE]
Verification
Post reply
Modular Amps
