Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Syn 2 + Syn 2
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MarcoR" data-source="post: 159283" data-attributes="member: 961"><p>Really depends, you can use the fx loop on the master SYN2 or between the output of the master and your power amp. If you're going for w/d/w, use the first output to the dry power amp and second output to your fx ( set 100% wet) then to your stereo power amp. No need to use the fx loop in this case</p></blockquote><p></p>
[QUOTE="MarcoR, post: 159283, member: 961"] Really depends, you can use the fx loop on the master SYN2 or between the output of the master and your power amp. If you're going for w/d/w, use the first output to the dry power amp and second output to your fx ( set 100% wet) then to your stereo power amp. No need to use the fx loop in this case [/QUOTE]
Verification
Post reply
Modular Amps
Syn 2 + Syn 2
