Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Syn 30
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="gtr31" data-source="post: 155678" data-attributes="member: 110"><p>The problem is you don't have a master really .If the actual head has no master and the master on the module is controlling volume the head is basically 30 watts on full so your volume will go from barely on to LOUD fast </p><p></p><p>try a mini recto ,its set up the same way , you have a gain and a master , its loud and not super bedroom friendly ,then they added the Mark35 with seperate ch master and overall masters ,thats a HUGE difference</p><p></p><p>I can live without the density but i think they should have added a master to be able to crank the modules into a sweet spot and then overall control it .</p><p></p><p>seems odd</p></blockquote><p></p>
[QUOTE="gtr31, post: 155678, member: 110"] The problem is you don't have a master really .If the actual head has no master and the master on the module is controlling volume the head is basically 30 watts on full so your volume will go from barely on to LOUD fast try a mini recto ,its set up the same way , you have a gain and a master , its loud and not super bedroom friendly ,then they added the Mark35 with seperate ch master and overall masters ,thats a HUGE difference I can live without the density but i think they should have added a master to be able to crank the modules into a sweet spot and then overall control it . seems odd [/QUOTE]
Verification
Post reply
Modular Amps
Syn 30
