Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
SYN 50 => Little Labs Redeye 3D Phantom (DI/reamp) => UAD Apollo => Computer results in huge high pitch squeal!
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="BTMagnus" data-source="post: 162277" data-attributes="member: 4567"><p>Hi</p><p></p><p>I have a disturbing problem with my setup and I've tried for a month to fix it and I've now reached a dead end. The problem is most likely not the Syn50 so I hope it's OK that I post my question here anyway cause I'm really lost at this point. Please help?? <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p></p><p>I recently bought a Synergy SYN50 amp and a Little Labs Redeye 3D Phantom (DI/reamp).</p><p>The purpose is to record the DI signal and the amp and that way having the option to reamp.</p><p></p><p>As soon as I connect the DI/Reamp box to my interface theres a huge squeal. If I then lift the ground on the DI/Reamp box the squeal goes away but the guitar tone doesn't sound great...thin and almost "electrified".</p><p></p><p>The problem seems to happen when the computer and the interface are connected to power at the same time which makes me think there's an ground loop issue. I've tried to connected the interface and computer to different power outlets, or the same outlets, lift the ground also on the SYN50, tried other cables etc but no luck. I've found a few people on different forums describing similar problems and relating it to ground loops but what seems to have been the solution for them hasn't worked for me so far. Anyone has any idea what I could try to fix this issue?</p><p></p><p>If anybody takes the time to respond to this - huge thank you in advance. Happy 2023 <img src="data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7" class="smilie smilie--sprite smilie--sprite1" alt=":)" title="Smile :)" loading="lazy" data-shortname=":)" /></p><p>// M</p></blockquote><p></p>
[QUOTE="BTMagnus, post: 162277, member: 4567"] Hi I have a disturbing problem with my setup and I've tried for a month to fix it and I've now reached a dead end. The problem is most likely not the Syn50 so I hope it's OK that I post my question here anyway cause I'm really lost at this point. Please help?? :) I recently bought a Synergy SYN50 amp and a Little Labs Redeye 3D Phantom (DI/reamp). The purpose is to record the DI signal and the amp and that way having the option to reamp. As soon as I connect the DI/Reamp box to my interface theres a huge squeal. If I then lift the ground on the DI/Reamp box the squeal goes away but the guitar tone doesn't sound great...thin and almost "electrified". The problem seems to happen when the computer and the interface are connected to power at the same time which makes me think there's an ground loop issue. I've tried to connected the interface and computer to different power outlets, or the same outlets, lift the ground also on the SYN50, tried other cables etc but no luck. I've found a few people on different forums describing similar problems and relating it to ground loops but what seems to have been the solution for them hasn't worked for me so far. Anyone has any idea what I could try to fix this issue? If anybody takes the time to respond to this - huge thank you in advance. Happy 2023 :) // M [/QUOTE]
Verification
Post reply
Modular Amps
