Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Syn50 Questions
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="baron55" data-source="post: 160893" data-attributes="member: 4246"><p>Also keep in mind the various preamps paired with the correct power amp will also be more representative.</p><p></p><p>For example PowerBall and SLO modules are best with 6L6 as that’s what the real amps had.</p><p></p><p>The Ecstasy and Vai modules are best with EL34 and the Uber sounds very good with all types depending on your flavor tastes.</p><p></p><p>I have tried the above modules with 6L6, EL34 and KT88 power sections and there is a huge difference in feel and response and tone.</p><p></p><p>Synergy uses 6L6 based power sections because the tubes are cheaper and more reliable and can take abuse better.</p></blockquote><p></p>
[QUOTE="baron55, post: 160893, member: 4246"] Also keep in mind the various preamps paired with the correct power amp will also be more representative. For example PowerBall and SLO modules are best with 6L6 as that’s what the real amps had. The Ecstasy and Vai modules are best with EL34 and the Uber sounds very good with all types depending on your flavor tastes. I have tried the above modules with 6L6, EL34 and KT88 power sections and there is a huge difference in feel and response and tone. Synergy uses 6L6 based power sections because the tubes are cheaper and more reliable and can take abuse better. [/QUOTE]
Verification
Post reply
Modular Amps
Syn50 Questions
