Synergy MIDI Pedal-SYN R5?
Mike P
Hey All,
Does anyone own the SYN R5 MIDI pedal and if so, is it easy to set up and use? I work in the studio only, so I don't need elaborate programming or awesome programmable gear like the Voodoo Lab Hex or GCX, just a simpler way to switch between the modules. I currently have four SYN-2's that I've been switching manually using the Bypass switch on the front of each unit and it would be nice to be able to control the modules with a pedal instead.
Thanks so much! 8)
