Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
T2 tube layout
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="El_Thwatez" data-source="post: 31827" data-attributes="member: 1142"><p>I'm gonna take a guess and say its the one on the left since its the shortest signal path, but either way, you could test this with a multimeter couldnt you? </p><p></p><p>Something like taking all the tubes out (TURN THE AMP OFF FIRST AND LEAVE IT OFF), put one end of the multimeter onto the live terminal on the jack input and then pop the other end into the inputs on each valve fitting, whichever one provides the least resistance is the right one... </p><p></p><p>I'm not an electronics guy though, so I don't know whether this is a flawed approach? </p><p></p><p>What are you specifically trying to achieve with having varied tubes in the preamp stage?</p></blockquote><p></p>
[QUOTE="El_Thwatez, post: 31827, member: 1142"] I'm gonna take a guess and say its the one on the left since its the shortest signal path, but either way, you could test this with a multimeter couldnt you? Something like taking all the tubes out (TURN THE AMP OFF FIRST AND LEAVE IT OFF), put one end of the multimeter onto the live terminal on the jack input and then pop the other end into the inputs on each valve fitting, whichever one provides the least resistance is the right one... I'm not an electronics guy though, so I don't know whether this is a flawed approach? What are you specifically trying to achieve with having varied tubes in the preamp stage? [/QUOTE]
Verification
Post reply
Off Topic
T2 tube layout
