Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
TOP BOOST BRIGHT TWITCH
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="MetalMajik" data-source="post: 6413" data-attributes="member: 62"><p>The bright swich's effect will vary depending on how high you have the gain turned up. It essentially works like a gain bypass swich for the high end (high end bypasses the gain knob). So if you have the gain knob maxed out the bright swich will not do anything.</p></blockquote><p></p>
[QUOTE="MetalMajik, post: 6413, member: 62"] The bright swich's effect will vary depending on how high you have the gain turned up. It essentially works like a gain bypass swich for the high end (high end bypasses the gain knob). So if you have the gain knob maxed out the bright swich will not do anything. [/QUOTE]
Verification
Post reply
Modular Amps
Modules
