Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Tube Bias Question
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="trendkill1168" data-source="post: 1138" data-attributes="member: 11"><p>I biased mine with the modules in. I warmed the tubes up and then flipped the standby switch to play and then checked the bias. </p><p></p><p>I think someone stated on here that you can use the Egnater modules in the Randalls but with the dual channel Egnaters you can only use 1 channel. I've never tried one so I am not an authority.</p></blockquote><p></p>
[QUOTE="trendkill1168, post: 1138, member: 11"] I biased mine with the modules in. I warmed the tubes up and then flipped the standby switch to play and then checked the bias. I think someone stated on here that you can use the Egnater modules in the Randalls but with the dual channel Egnaters you can only use 1 channel. I've never tried one so I am not an authority. [/QUOTE]
Verification
Post reply
Modular Amps
Tube Bias Question
