Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
Using Modules with 12BZ7
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Jaded Faith" data-source="post: 136949" data-attributes="member: 1068"><p>Although you can try them, I'd be careful. Voltage isn't really at issue, as the 12BZ7 operates at the same voltage as a 12AX7. The 12BZ7 has twice the transconductance, but half the plate resistance of the 12AX7 spec. This still leaves it at roughly the same amplification factor, but the heater draws twice the current. If you blow the heater fuse in the amp, that's the cause.</p></blockquote><p></p>
[QUOTE="Jaded Faith, post: 136949, member: 1068"] Although you can try them, I'd be careful. Voltage isn't really at issue, as the 12BZ7 operates at the same voltage as a 12AX7. The 12BZ7 has twice the transconductance, but half the plate resistance of the 12AX7 spec. This still leaves it at roughly the same amplification factor, but the heater draws twice the current. If you blow the heater fuse in the amp, that's the cause. [/QUOTE]
Verification
Post reply
Modular Amps
Modules
