Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
Want a modern Marshall sound
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="eyeball987" data-source="post: 135236" data-attributes="member: 2141"><p>Boost the front end. Use some type of OD box with the level up and the gain down. Depending on the boost used, you will get different shades of what you already have with with more saturation. </p><p></p><p>I use a Koko Boost, MXR Classic OD, or a Cool Cat Trans OD. Lots of love for the old standard SD1 or Tube Screamer for boosting Marshalls also. </p><p></p><p>I have used (sometimes still do) the speaker mix you are talking about and have no problem getting modern tones if I want them. Swapping out the CL80's for G12T75's might help also. That is pretty much the standard speaker mix for modern amps. I personally prefer the CL80's though.</p><p></p><p>I guess I should have asked, have you tried boosting? Do you have a decent OD pedal laying around?</p></blockquote><p></p>
[QUOTE="eyeball987, post: 135236, member: 2141"] Boost the front end. Use some type of OD box with the level up and the gain down. Depending on the boost used, you will get different shades of what you already have with with more saturation. I use a Koko Boost, MXR Classic OD, or a Cool Cat Trans OD. Lots of love for the old standard SD1 or Tube Screamer for boosting Marshalls also. I have used (sometimes still do) the speaker mix you are talking about and have no problem getting modern tones if I want them. Swapping out the CL80's for G12T75's might help also. That is pretty much the standard speaker mix for modern amps. I personally prefer the CL80's though. I guess I should have asked, have you tried boosting? Do you have a decent OD pedal laying around? [/QUOTE]
Verification
Post reply
Modular Amps
Modules
