Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Synergy Amps & Modules
Wet/Dry/Wet Configuration
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mahatma" data-source="post: 159475" data-attributes="member: 4035"><p>Here is another thought about creating a W/D/W rig which would eliminate a second stereo power amp for the wet signal. Connect the SYN-2 as normal to a power amp like the SYN5050 by using the Main Outs, and using the power amp to drive a normal speaker cab for the dry signal. Then connect the SYN-2s DI Outs, with the cab simulator on, to the inputs of a stereo FX unit and the outputs of the FX unit to two powered speakers, like a pair of QSC K12, for the stereo wet signals.</p><p>I'm guessing that this idea of using the DI Outs/Simulated Cab, into and FX unit, then into a pair of Powered Speakers for the stereo wet signal, can also be used if the SYN-2 was connected into the FX loop of a regular amp head or combo. In this case the dry signal would simply pass to the head's or combo's power section and onto to the amp's speakers.</p></blockquote><p></p>
[QUOTE="mahatma, post: 159475, member: 4035"] Here is another thought about creating a W/D/W rig which would eliminate a second stereo power amp for the wet signal. Connect the SYN-2 as normal to a power amp like the SYN5050 by using the Main Outs, and using the power amp to drive a normal speaker cab for the dry signal. Then connect the SYN-2s DI Outs, with the cab simulator on, to the inputs of a stereo FX unit and the outputs of the FX unit to two powered speakers, like a pair of QSC K12, for the stereo wet signals. I'm guessing that this idea of using the DI Outs/Simulated Cab, into and FX unit, then into a pair of Powered Speakers for the stereo wet signal, can also be used if the SYN-2 was connected into the FX loop of a regular amp head or combo. In this case the dry signal would simply pass to the head's or combo's power section and onto to the amp's speakers. [/QUOTE]
Verification
Post reply
Modular Amps
