Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
What does C7 & C13 do?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="Gee Donner" data-source="post: 18646" data-attributes="member: 1101"><p>By putting capacitors in parallel with the cathode resistors you do boost the gain, but only in different frequency ranges. That causes more gain. So it contributes a little to the amount of gain. But the main reason why the ultra has so much gain is a factor of how the circuit is designed and how much impedance between each gain stages it has. </p><p></p><p>///GT</p></blockquote><p></p>
[QUOTE="Gee Donner, post: 18646, member: 1101"] By putting capacitors in parallel with the cathode resistors you do boost the gain, but only in different frequency ranges. That causes more gain. So it contributes a little to the amount of gain. But the main reason why the ultra has so much gain is a factor of how the circuit is designed and how much impedance between each gain stages it has. ///GT [/QUOTE]
Verification
Post reply
Modular Amps
Modules
