Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
General Forum Information
Off Topic
whats in front of your t2?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="El_Thwatez" data-source="post: 20567" data-attributes="member: 1142"><p>I have an obsession with tightness and for me, the T2 is one of those amps that should be run raw, it sounds so ballsy on its own, the only kit id recommend is a boss NS2 set up as RD Rich has suggested (see previous post), and a good cab and speakers setup really makes a difference. </p><p></p><p>In my opinion, I don't think you could find a tighter amp, seriously, but again, get a good set of speakers to accentuate the tightness - I'm using a smaller sized 4x12 cab with some old Fanes which creates a monsterously tight sound with a really strong punch. </p><p></p><p>The guitar you use also has a strong effect on the tightness too, I use a Dime333 + FM333 (I like the shape + the feel of Washburns, I don't pretend to be Dime), the Dime is Alder and the FM is all Mahogany and the FM is a much tighter guitar, the Dime has a sloppy low end. Then finally, technique is they key to tightness.</p><p></p><p>Apart from that I got an Ibanez Weeping Demon in the front and an EH Hot Tubes Post-Pre for a dirty gain boost when needed!</p></blockquote><p></p>
[QUOTE="El_Thwatez, post: 20567, member: 1142"] I have an obsession with tightness and for me, the T2 is one of those amps that should be run raw, it sounds so ballsy on its own, the only kit id recommend is a boss NS2 set up as RD Rich has suggested (see previous post), and a good cab and speakers setup really makes a difference. In my opinion, I don't think you could find a tighter amp, seriously, but again, get a good set of speakers to accentuate the tightness - I'm using a smaller sized 4x12 cab with some old Fanes which creates a monsterously tight sound with a really strong punch. The guitar you use also has a strong effect on the tightness too, I use a Dime333 + FM333 (I like the shape + the feel of Washburns, I don't pretend to be Dime), the Dime is Alder and the FM is all Mahogany and the FM is a much tighter guitar, the Dime has a sloppy low end. Then finally, technique is they key to tightness. Apart from that I got an Ibanez Weeping Demon in the front and an EH Hot Tubes Post-Pre for a dirty gain boost when needed! [/QUOTE]
Verification
Post reply
Off Topic
