Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
Which tubes for mods
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="ktno78" data-source="post: 142179" data-attributes="member: 3462"><p>On the doug's tubes, they say that JJ and ruby are the same</p><p>"The Ruby 12AX7ACZ High Grade is a re-labeled JJ ECC83" and "Also known as the Groove Tubes ECC83-S and Ruby 12AX7ACZ HG" for the Ruby 12AX7ACZ HG and the JJ ECC83S</p><p></p><p>And for clean module like JF superclean or JF Texasspecial (more warm), which kind of tubes are you using/recommend</p></blockquote><p></p>
[QUOTE="ktno78, post: 142179, member: 3462"] On the doug's tubes, they say that JJ and ruby are the same "The Ruby 12AX7ACZ High Grade is a re-labeled JJ ECC83" and "Also known as the Groove Tubes ECC83-S and Ruby 12AX7ACZ HG" for the Ruby 12AX7ACZ HG and the JJ ECC83S And for clean module like JF superclean or JF Texasspecial (more warm), which kind of tubes are you using/recommend [/QUOTE]
Verification
Post reply
Modular Amps
Modules
