Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Modules
XTC treble Not working
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="DSY555" data-source="post: 159981" data-attributes="member: 4115"><p>treble isn't working at all. The rest of the tone stack seems ok. I replaced cap in c19 and tested the treble pot . Pot is good. no change with a cap in c19 or without a cap in c19. Anything else i should check in the tone stack? I'm guessing c19 is a coupling cap. Is there other parts concerning the treble that i should check first? Could a bad resistor cause this to happen? I just think that if there was a fault with any of these parts i wouldn't get sound at all. Thanks for any suggestions</p></blockquote><p></p>
[QUOTE="DSY555, post: 159981, member: 4115"] treble isn't working at all. The rest of the tone stack seems ok. I replaced cap in c19 and tested the treble pot . Pot is good. no change with a cap in c19 or without a cap in c19. Anything else i should check in the tone stack? I'm guessing c19 is a coupling cap. Is there other parts concerning the treble that i should check first? Could a bad resistor cause this to happen? I just think that if there was a fault with any of these parts i wouldn't get sound at all. Thanks for any suggestions [/QUOTE]
Verification
Post reply
Modular Amps
Modules
