Forums
New posts
Search forums
What's new
New posts
New profile posts
Latest activity
Members
Current visitors
New profile posts
Search profile posts
Log in
Register
What's new
Search
Search
Search titles only
By:
New posts
Search forums
Menu
Log in
Register
Install the app
Install
Modular Amps
Jaded Faith Mods
Yellow Jackets for EL84 tubes in RM100?
You should upgrade or use an
alternative browser
Reply to thread
Message
<blockquote data-quote="mikegyver" data-source="post: 123289" data-attributes="member: 3148"><p>I use yellowjackets in my MOD50 all the time, they are great! My only gripe is that they are tall and extend quite far to where you have to put the yellowjackets in and then the tubes (not both at the same time as one piece).</p><p>So they are just a little long with the tubes, but not a big deal.</p><p></p><p></p><p></p><p>They would sound probably identical since the voltage would be really similar. I use my MOD50 with the EL84s in half-power mode all the time and sounds great (99.96% the same as full-power mode). </p><p></p><p>IMO you would probably be fine doing this but I would get the OK from Bruce or Rob before cutting the wattage down this low (1/2 from yellow jackets and 1/2 again with only 2 tubes).</p></blockquote><p></p>
[QUOTE="mikegyver, post: 123289, member: 3148"] I use yellowjackets in my MOD50 all the time, they are great! My only gripe is that they are tall and extend quite far to where you have to put the yellowjackets in and then the tubes (not both at the same time as one piece). So they are just a little long with the tubes, but not a big deal. They would sound probably identical since the voltage would be really similar. I use my MOD50 with the EL84s in half-power mode all the time and sounds great (99.96% the same as full-power mode). IMO you would probably be fine doing this but I would get the OK from Bruce or Rob before cutting the wattage down this low (1/2 from yellow jackets and 1/2 again with only 2 tubes). [/QUOTE]
Verification
Post reply
Modular Amps
Jaded Faith Mods
