New Head switcher
Post Egnater & Randall MTS amps, modules and cab for sale and wanted. Please no dealers.
bruce egnater
Bruce Almighty
New Head switcher
Post by bruce egnater » Tue May 27, 2014 7:55 pm
Working on a new design, handmade, 2 heads into 1 cabinet switcher. Unique, transformerless output buffers, silent switching. Estimated direct price around $350. Interest? Suggestions?
Thanks
Bruce
begnater@aol.com[/img]
AdInfinitum
Post by AdInfinitum » Tue May 27, 2014 10:26 pm
Bruce:
I may be up for one. I currently run an M100 and RM100 into a Mesa Cabinet. I use a HeadBone (or CabBone - can't remember) by Radial to switch between the two heads and then use a Randall Bigshot (or Hotshot - again can't remember) to switch the guitar inputs. It works, but would love something a little less complicated, although the Radial stuff works great.
Todd the Trademark Attorney
TrademarkAuthority
Johnny Wadd
Post by Johnny Wadd » Wed May 28, 2014 7:15 am
Oh lord. I've been looking for something to do this.
1) switch between two tube heads
2) switch between two cabs and/or stereo capability
3) midi controllability
4) use my ground control to switch it all
Basically want to be able to switch between my rm100 mono and an rt250 stereo using the same two cabs. Possible?
doornat
Post by doornat » Wed May 28, 2014 11:55 am
I use two tube heads and two 2x12s and just switch back and forth between them with the new MXR A/B box, but I'd love to just run a single 2x12.
PRS Custom 22 + Chromasurf Les Paul + Jackson Soloist Prototype 7 string + Marshall DSL100 + EVH 5150iii + Randall RM100 + PRS Archon<3
Post by Mattfig » Wed May 28, 2014 12:11 pm
I have a head switcher from tedweber that allows me to switch two heads into one cab and has a footswitch but NO MIDI...However, it was considerably less...In fairness there is also a slight "pop" when you switch...I would like MIDI.... :) It would be worth the additional cost!
Zander
Post by Zander » Wed May 28, 2014 12:18 pm
Definite Interest. :)
Jacksauce
Post by Jacksauce » Wed May 28, 2014 2:52 pm
Another vote for MIDI. Or at least a footswitch.
dr. Feelgood, Camerock, Erecto, GM Recto, Rhoadie, XMG, Mark X, JF SM DF XTC, Trilogy, Angel, Mamba & SE, Markus, Mash-All, Ubersonic
Hernando04
Post by Hernando04 » Thu May 29, 2014 9:03 am
I use the Egnater S4. It switches between 4 heads into 1 cab and is midi controllable. It also has a single line out with 4 level controls for each of the 4 amps. You can use that if you want to run a wet/dry setup, but the wet side would require another cab. Or run the whole thing into a split cab. Bruce, Is this new device a simpler version of the S4 or is there some improvement you have made over the S4?
Multiple M4s and dualie modules
guitarzan
Post by guitarzan » Thu May 29, 2014 11:05 pm
The S4 sounds really cool. I could definitely have fun with something like that. Is that what you're doing Bruce?
Syn1, Syn2, Syn50/50, MOD50, M4, Hilly's RM100 modded to dual, RM4 modded to dual channel. G-Major 2, Eventide Eclipse, Mesa 20/20, Fryette Powerstation, Friedman Smallbox Combo, 1979 Marshall JMP 50 modded to BE/HBE by Friedman. Tons of modules.
lintycreep
Post by lintycreep » Fri May 30, 2014 6:38 am
Count me in Bruce.
SM: Masholdano, Baseman, Camerock,
SG: Fisch
Stock duels: COD
Ulf
Post by Ulf » Wed Jun 04, 2014 3:47 am
Ulf
RM4, RM1250, MOD100
too many modules
Post by Mattfig » Wed Jun 04, 2014 3:57 am
Ulf wrote:Has anyone seen these?
http://ampete.com/products/switcher-series/
:shock:
Tbag
Post by Tbag » Tue Jul 01, 2014 4:21 am
Yep i'm in!
Bare-Metal-Mods:
Heavily modded RM100, Lynchbox,
RectReFiner x2, Vox30, Blueface, 1086
Boss GT Pro, Fractal MFC-101,
Mesa Cabs
bruce egnater
Bruce Almighty
Post by bruce egnater » Mon Jul 14, 2014 9:30 pm
Still testing and refining. Looks like there may be 3 or 4 models with progressively more features. Will keep you posted.
maxxstock
Post by maxxstock » Tue Jul 15, 2014 12:49 am
Mattfig wrote:I have a head switcher from tedweber that allows me to switch two heads into one cab and has a footswitch but NO MIDI...However, it was considerably less...In fairness there is also a slight "pop" when you switch...I would like MIDI.... :) It would be worth the additional cost!
Hi Matt)))
RJM Y-not worked fine for me.
I have one for sale :wink:
The aim and final end of all music should be none other than the glory of God and the refreshment of the soul.
"Johann Sebastian Bach"
