RM20 no sound after a couple minutes
Thought it was a tube but I replaced everything and it still dies down to no sound after a few minutes from standby. Could it be a cap gone bad? Diodes, failing resistor. Not sure what to look for if anyone has experienced this or has an idea. I’m stumped. Not the module as it does it with anything I put in it.
- RM100
Re: RM20 no sound after a couple minutes
Sorry for the late reply but in reality it’s probably going to be best to get this to a qualified repair tech to test things. Unless you are savvy and knowledgeable with this stuff I only mention this as there are lethal voltages inside any tube amp.
In reality with what you are describing assuming it’s not a tube or loose speaker connection it’s possible this is a failing output transformer.
Jaded Faith - VLUX, Hot Rod Tweed, Chiefton, Superpro, SVT
Egnater M4 with dual channel and 3-way cathode bias mods
Randall RM20 with Eminence JS-1250
Salvation Mods - Loneclean II, Matchvox II, H-Watt, Stonerverb DeLarge, Ampig
