Could I use these to run EL84s
Discussion for both Egnater & Randall modular amps
Spencer4hire
Post by Spencer4hire » Sat Mar 12, 2011 3:07 am
http://www.premierguitar.com/Magazine/I ... ial_6.aspx
Would these work for putting EL84s in my RM100?
Here is another link.
http://www.vhtamp.com/avspad.html
bduersch
Post by bduersch » Sat Mar 12, 2011 7:59 am
Hard to tell if those are specifically designed for VHT amps or not...
if you're looking to use EL84's though, how about THD yellowjackets in an RM100?
--B
Hamner1
Post by Hamner1 » Sat Mar 12, 2011 11:14 am
From the PG site:
"The Special 6 EL84 adapter works in other 6V6 amps as well. VHT recommends checking with an amp tech to be sure your amp?s voltages don?t exceed the maximum ratings for an EL84".
It sounds like the 100 would work if the voltage doesn't exceed the 84's ratings.
Non-MTS stuff for sale.
Good deals with: warlock, sickpunk, marinebassplayer, Rising Farce, durchgedreht, mattfig, & others.
Rod
Post by Rod » Sun Mar 13, 2011 3:04 am
I have a pair of Groove Tube EL84 converters that I have used with my RM 50 as well as my RM100...I'm not using them now,,,You could have the pair for $50 IF YOU WANT THEM...with a pair of new EL84's they'd be a bit more
