driving more than one amp from guitar.. hey Fig
Discussion for both Egnater & Randall modular amps
eedude
Post by eedude » Sat Mar 12, 2011 6:09 pm
those of you that are driving more than one amp from your guitar, what are using to interface between the guitar and the amps?
I'm trying to run two amps just using a Boss stereo chorus, but I get a ground loop....
Good Deals w/ randall3, cold Machine, El Dangerouso, tonelover, Seano, jitterybit, alowerdeep
Prog for all: http://www.myspace.com/onyxguild
Re: driving more than one amp from guitar.. hey Fig
Post by Mattfig » Sat Mar 12, 2011 6:19 pm
eedude wrote:those of you that are driving more than one amp from your guitar, what are using to interface between the guitar and the amps?
Well, my solution to run multiple preamps and such is a Voodoo Labs GCX Guitar Audio Switcher along with a Ground Control Plus pedal....There's one on rig-talk right now for 600...I know it's pricey but it's awesome....
eedude
Post by eedude » Sat Mar 12, 2011 6:28 pm
thank fig, yeah.. big bucks! fig once you see my rig you're gonna cry :twisted:
SacredGroove
Post by SacredGroove » Sat Mar 12, 2011 6:28 pm
Which is cool, because the GCX has a built in buffer, before the loops.
__Scott__
Post by Mattfig » Sat Mar 12, 2011 6:57 pm
Plus, Sacred Groove talked me thru my first steps into MIDI and now I am an addict....I can't believe I always avoided using it....Life is easy with it once it's all programmed...
And eedude...Uh oh...I might need to add that other RM4 to keep up with the Joneses...???...Can't wait to see it bro!
crankyrayhanky
Post by crankyrayhanky » Sat Mar 12, 2011 7:12 pm
use this on 1 of the amps,problem solved:
http://www.ebtechaudio.com/humxdes.html
Rod
Post by Rod » Sun Mar 13, 2011 3:17 am
RAY'S SOLUTION IS THE BEST AND SAFEST..The emergency version is to lift the ground on 1 of the amps....You use those grey 3 into 2 connectors that go on the end of the power cord..Cost about 80 cents....but your 1 amp is not grounded..
bduersch
Post by bduersch » Sun Mar 13, 2011 7:21 am
Try to find an Axess Electronics BS1 buffer... great piece of kit which has an isolated output (for ground loops) as well as a phase switch (always a risk when playing with 2+ amps).
I've tried the Ebtech hum eliminator... have mixed feelings on it... it is a "miracle device" for killing ground loop hum, but in some applications I've found it to be a tone suck. Probably won't know for sure until you try it yourself.
--B
m0jo
Post by m0jo » Sun Mar 13, 2011 7:51 am
Rod wrote:RAY'S SOLUTION IS THE BEST AND SAFEST..The emergency version is to lift the ground on 1 of the amps....You use those grey 3 into 2 connectors that go on the end of the power cord..Cost about 80 cents....but your 1 amp is not grounded..
In other words: NEVER do this..
It's just not safe, just run a buffer with ground lift in line to one of the amps, that's even easyer.
Or something like this: http://pro-audio.musiciansfriend.com/pr ... sku=180014
There are stacks of these types of boxes.
Just run them in the signal path to one amp and you're golden.
Otherwise there's the Lehle P-Split, specially for this application.
Or the Gig-rig buffer pedal. I believe the Toadworks Banana buffer also does buffered splitting :) (and ground lifting)
Salvation Mods Twinface, Mash-all+, Sloogie, Mu?eca, Shiver (Facelift), modded XTC, stock Recto
Randall RM4 - Randall RT2/50 - Randall RM22
TT-Cabs REX V212
www.sparkplugmusic.nl
crankyrayhanky
Post by crankyrayhanky » Sun Mar 13, 2011 9:38 am
I've never had this said about me, much less in CAPS, lol...my ideas are often described as Bad & Dangerous.
Regarding the "tone suck" issue, how could that be? It's basically converting power, so only 1 amp is grounded and the amp in the Ebtech is a safer version of a 2 prong? IDK, I never heard tone suck with this method.....though I haven't used it in a while, I used to run (2) rm100s but now I'm down to (1)
eedude
Post by eedude » Sun Mar 13, 2011 11:00 am
Rod wrote:..You use those grey 3 into 2 connectors that go on the end of the power cord..Cost about 80 cents....but your 1 amp is not grounded..
$0.80 is too much, i'd just cut the third prong off the IEC power cable :shock:
just kidding... yeah i know that's all bad. Some of the boxes mentioned must have isolation transformer... else it wont break the loop. ... Crankyray's suggested product does not go in the guitar path, which makes it very attractive...
all good ideas, keep 'em coming... i've goat an idea or two i'm gonna try today...
crankyrayhanky
Post by crankyrayhanky » Sun Mar 13, 2011 11:10 am
in the past I've had ground switches on amps that seemingly did nothing. However, the ebTech is very effective for the 2 amp setup
before ebtech: BIG hum in 1 amp
after: Zero Hum (or at least back to normal for a hi gain amp)
bduersch
Post by bduersch » Mon Mar 14, 2011 4:41 am
You're right... I wasn't thinking about the Hum-X (which interacts with the power line)... I was thinking about the Hum Eliminator ( http://guitars.musiciansfriend.com/prod ... sku=150450 ) when I wrote that. The Hum Eliminator works miracles but since it interacts with the audio signal can cause tone suck.
--B
Mike P
Post by Mike P » Mon Mar 14, 2011 7:17 pm
This the finest switching product on the market, bar none:
http://guitars.musiciansfriend.com/prod ... D=26018792
Radial Switchbone. It'll meet all of your needs and then some.
www.mikeplas.com
Jaded Faith: Vybe Deluxe
Sacred Groove: MK22+|Rectifier
Salvation: Camerica
Synergy: SYN-2(4)|Diezel VH4|ENGL Savage|Friedman HBE|Metro Plex|Soldano SLO
Synergy Amps Artist: http://synergyamps.com/artists
kc2eeb
Post by kc2eeb » Tue Mar 15, 2011 7:31 pm
Thoughts about Ground Lift, Ground adapters and loops.
First, are both amps plugged into the same socket?
Second, if you lift the ground from one amp (using a ground adapter)
and you have the guitar cable going from one amp to another, it is still
grounded PROVIDED that the shield of the guitar cable is connecting the two chassis. That's why the RM4 has a ground lift switch. It's to eliminate ground LOOPS, not to disconnect the ground connection.
It's easy to check. With all the cables plugged in, use a multimeter to check for continuity between the chassis ground of both amps. If you lift the ground from ONE amp and it shows continuity between the amp chassis, as long as
ONE AC cord is connected to ground, you've got it.
The idea is to have ONE path to ground.
