Blue LED's are cool!!
warlok
AZ
Been wanting to put LED lighting on my amp for a while.. $23 on ebay for power supply and 2 LED strips. I like it!!
Extremely easy. The power supply has 2 output plugs and came with screw on adapters for the LED strips. Took all of 5 minutes to get it all set up. Here's the ebay ads I used.
Power supply - http://www.ebay.com/itm/181028893463?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
LED strips - http://www.ebay.com/itm/170858542017?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Beautiful!!
But is this mounted so you can move the amp to a gig and such? Im wondering if you have to remount it each time you move the amp...
GtrGeorge
looks great!
How did you hook power up? Did you tap the fan wires or did you have to plug into the wall?
The strips are peel and stick and I just stuck them under the lip of the cab and just inside the front plate on the top/inside of the head cabinet. The wires from them go to the screw on barrel adapters that came with the power supply. So I can disconnect them and move as necessary. The power supply is a stand alone unit and connects to the strips with barrel connectors just like a pedal power supply. I'm gonna velcro it to the back or side of my cab (right now it's just sitting inside the handle). Completely connect/disconnectable and portable.
