My RM-100 is Dead!
Corium_AZ
My RM-100 is Dead!
Post by Corium_AZ » Sat Nov 22, 2014 3:47 am
Well godammit, my RM100 took a crap on me tonight. Was playing at my normal volume thru my silent rig - THD Hotplate as load box, direct out to my interface, etc... In any case, it just shut right down on me. No power at all. No power led lights when the mains switch is on. No fuse led's. Nothing. Checked all tube fuses, all good. Promptly Removed chassis, checked all internal fuses. All good to go. No smoke, no smells, no burnt resistors or pcbs. Looks as new inside. Of course this happens at 2am, and I have band practice tomorrow...
So, at this point I guess I have to assume I either fried the PT or lost a cap. I'm no electronics expert, but pretty good at figuring things out & fixing issues. So, how do I test a Xformer? And, is there anything else I should look for/at?
Any help is appreciated for sure as I don't think I can live without it for too long. It is my only amp. I suppose I'll be using my lead guitarists JMP until I can get this sorted out. Oh, the horror, I know, lol!
Band Sites (Until The Sun)
http://www.reverbnation.com/untilthesun
https://www.facebook.com/UntilTheSunBand
Budda Superdrive 45, Orange Rocker 30, Zinky 4x12, '72 Deluxe Tele and MIJ Greco LP Custom
kc2eeb
Egnater/Randall Modular Amps
Post by kc2eeb » Sat Nov 22, 2014 10:39 am
Check the simple stuff first. The speaker impedance switch, speaker cable (with a meter), do that first.
warlok
Post by warlok » Sat Nov 22, 2014 11:37 am
Unless I missed it.. I didn't see that you checked the main fuse. Did you?
Jackson, Charvel, Ibanez. RM100, RM50 (both Foglifted), JF Erect, MarkX, '59RR, XTC, Stock KH1 & 1086. Carvin 4x12 with G12T-75's/V30's X-pattern, Randall R212CS with older Eminence OEM's
JKD
Post by JKD » Sat Nov 22, 2014 11:40 am
warlok wrote:Unless I missed it.. I didn't see that you checked the main fuse. Did you?
Had exactly same thought myself.
Pull the fusebox right by the mains cord....note that it's able to be put back in many ways..the little arrow next to it should currently be pointing to the 120V markings n it...put it back that way (if you are in US of course!)
Synergy - HBE,SLO,VH4,TDLX,Plexi, ENGL,OS,BB/BE, AC
JF-Dual Erect
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD, ERECT, VX
Corium_AZ
Post by Corium_AZ » Sat Nov 22, 2014 12:16 pm
Yes, I did check the mains fuse. I guess I forgot to include it in my post. It too is unscathed...
kc2eeb
Post by kc2eeb » Sat Nov 22, 2014 6:14 pm
Check the AC cord, the wall outlet for voltage, etc.
Also, check the fuse with a multimeter, not just visually.
Corium_AZ
Re: Egnater/Randall Modular Amps
Post by Corium_AZ » Sat Nov 22, 2014 6:46 pm
kc2eeb wrote:Check the AC cord, the wall outlet for voltage, etc.
Did all these first thing, everything good to go.
kc2eeb
Post by kc2eeb » Sat Nov 22, 2014 11:15 pm
Check the power switch switch on the amp for continuity?
Corium_AZ
Post by Corium_AZ » Sun Nov 23, 2014 2:12 pm
kc2eeb wrote:Check the power switch switch on the amp for continuity?
Didn't think of that, but I'll test it tonight. Not sure how something like that would fail randomly, but stranger things have happened I suppose.
Corium_AZ
Post by Corium_AZ » Wed Nov 26, 2014 10:57 am
Ok, well I got it fixed last night... It was in-fact the mains fuse after all. Strange thing, it checked out on continuity test, but had very high resistance. Maybe partially blown? I dunno, very strange. But I threw in a new fuse and fired right up & plays just fine. Like nothing ever happened. Weird, but I'm happy!
kc2eeb
Post by kc2eeb » Wed Nov 26, 2014 11:13 am
There you go. Fuses can be defective like anything else. BTW, when it measured very high resistance was it in the megaohms?
Were your fingers in contact with both of the probe tips?
You might have been measuring your own body resistance.
Corium_AZ
Post by Corium_AZ » Wed Nov 26, 2014 11:34 am
kc2eeb wrote:There you go. Fuses can be defective like anything else. BTW, when it measured very high resistance was it in the megaohms?
It was in Mohms, iirc. I measured while it was still in the plastic 'holder' dealio. Thing is, it checked out on continuity, so I just moved on. And, the filament appears in-tact & no burn marks on glass or anything. Looks brand new. Rather strange IMO, but just glad I checked it instead of start replacing parts, lol.
Thanks for the help/suggestions. It is appreciated.
kc2eeb
Post by kc2eeb » Wed Nov 26, 2014 11:45 am
At one time, "long ago,"a defective fuse was very uncommon. Not anymore.
I'm just as guilty as anyone else in not following the "standard troubleshooting sequence" and thinking it's a worst case scenario, but it really pays to check the obvious. Having to replace a transformer is actually a rarity. Having said that I did replace the OT and PC board on my RM50. Glad I did it when they were still easy to get.
