Randall RM50 - Master Volume Boost problem...
Discussion for both Egnater & Randall modular amps
Joe_Easy
Post by Joe_Easy » Fri Jun 12, 2015 4:31 am
Hi there,
I'm experiencing an issue, which I think might be related to the master volume boost cicruit. The amp randomly and without warning goes full-whack and requires either a switch in and out of standby, or sometimes a complete power-cycle to reset. I don't have a footswitch connected to the jack, so it's not an issue there. Anyone else experienced this, or have any ideas what might be causing it?
Cheers.
Post by Mattfig » Fri Jun 12, 2015 4:47 am
Hey Joe,
I would start by cleaning the footswitch in with some deoxit...But I am not sure I fully understand your problem...
Good place to start nonetheless...
Joe_Easy
Post by Joe_Easy » Fri Jun 12, 2015 5:06 am
Mattfig wrote:Hey Joe,
I don't have a footswitch attached, so it is nothing relating to that...I have used a footswitch in the past just to test the feature, and when I engage it, the result is the same as the intermittent problem I am experiencing; master volume goes to full.
webrthomson
Post by webrthomson » Fri Jun 12, 2015 6:32 am
I'd call Rob at Jaded Faith - I think he would know this off the top of his head :D
warlok
Post by warlok » Sat Jun 20, 2015 2:21 pm
Even if you don't use it, clean the MVB jack. Just spray a plug with some type of contact cleaner and plug in and out a few times. Repeat a few times.
Jackson, Charvel, Ibanez. RM100, RM50 (both Foglifted), JF Erect, MarkX, '59RR, XTC, Stock KH1 & 1086. Carvin 4x12 with G12T-75's/V30's X-pattern, Randall R212CS with older Eminence OEM's
Joe_Easy
Post by Joe_Easy » Mon Jun 22, 2015 6:58 am
warlok wrote:Even if you don't use it, clean the MVB jack. Just spray a plug with some type of contact cleaner and plug in and out a few times. Repeat a few times.
Hi there, yes, I made contact with Rob at Jaded Faith who recommended the same. It appears to have worked.
Cheers.
