Known issues with RM100?
Rilke
Post by Rilke » Tue Nov 14, 2017 3:59 pm
I've just recently ventured into the MTS world through buying a relatively cheap RM100. Are there any generally known issues with these amps I should check for ?
Best regards
Christian
webrthomson
Re: Known issues with RM100?
Post by webrthomson » Tue Nov 14, 2017 5:33 pm
Rilke wrote:I've just recently ventured into the MTS world through buying a relatively cheap RM100. Are there any generally known issues with these amps I should check for ?
Best regards
Christian
The early ones had a tendancy to board arc - if that has happened you will (probably) see burn marks on the PCB. They are pretty sturdy amps in the main - I've yet to have a RM100 fail thats not my fault :)
Rilke
Post by Rilke » Thu Nov 16, 2017 1:51 am
Hey Thanks for the answer! Happy to hear that. Is there a (relatively) easy way to see if mine is one of the older ? Besides the burnmarks on the PCB hehe :)
webrthomson
Post by webrthomson » Thu Nov 16, 2017 7:48 am
Rilke wrote:Hey Thanks for the answer! Happy to hear that. Is there a (relatively) easy way to see if mine is one of the older ? Besides the burnmarks on the PCB hehe :)
I'm not sure - I'd email Rob at Jaded Faith mods he will be able to tell you!
dinmonster
Lose screws
Post by dinmonster » Fri Jun 01, 2018 2:33 pm
The amps make it loud! High spl cause vibration and screws will back themselves out! When an internal ground is from a board to the chassis it can be a nightmare to detect! So baton down the hatches mate.... :lol:
DIN MONSTER
