RM50 Mod for Synergy 2 channel Modules
Discussion for both Egnater & Randall modular amps
Panthersn
Post by Panthersn » Thu Apr 19, 2018 12:10 pm
Love my RM50 and would love to access both channels of the Synergy modules. I know there is a Midi mod for the RM4, any ideas of accessing the second module channels? I'm trying to avoid the purchase of a SYN 2
tnjazz
Post by tnjazz » Thu Apr 19, 2018 12:20 pm
There is no mod for the RM50 unfortunately.
Yeah I’m still in the game...for now at least...
webrthomson
Re: RM50 Mod for Synergy 2 channel Modules
Post by webrthomson » Sat Apr 21, 2018 5:26 am
Panthersn wrote:Love my RM50 and would love to access both channels of the Synergy modules. I know there is a Midi mod for the RM4, any ideas of accessing the second module channels? I'm trying to avoid the purchase of a SYN 2
You coould see if you could find an Egnater MOD50 - like a RM50 but with Midi - the drawback is you can only use Synergy modules on the right hand module bay as the Synergy modules are deeper.
JKD
Post by JKD » Sat Apr 21, 2018 1:19 pm
If you can mod the backplane of the RM100 to switch channels then am honestly not sure why it cannot be done on the RM50...you won't have MIDI but I'm sure some enterprising soul could get up a DPST switch to assert (provide voltage) to the pin/select for the second channel of the module?
Rob?
Synergy - HBE,SLO,VH4,TDLX,Plexi, ENGL,OS,BB/BE, AC
JF-Dual Erect
Gigmods - Mark
Hilly-Snorkeler
Egnater -COD, ERECT, VX
Randall - Brahma,Scary, Grail, SuperV
MarcoR
Post by MarcoR » Mon Apr 23, 2018 8:56 am
I'm kind of surprised more people haven't taken on this type of mod. Once you got a latching footswitch to work, you could take it to the next level with an external midi function switch and have full midi control like with any other non-midi amp.
This dude modded his..
http://mtsforum.grailtone.com/viewtopic.php?t=20898
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
JKD
Post by JKD » Mon Apr 23, 2018 9:19 am
MarcoR wrote:I'm kind of surprised more people haven't taken on this type of mod. Once you got a latching footswitch to work, you could take it to the next level with an external midi function switch and have full midi control like with any other non-midi amp.
Thanks for finding that again Marco...I couldn't remember which pins they were....
It could be done even simpler than this if all you wanted was a switch on the front of the amp to select A or B....but this dudes solution is gig worthy.
JF-Dual Erect
Gigmods - Mark
Hilly-Snorkeler
tnjazz
Post by tnjazz » Wed Jun 27, 2018 4:29 pm
Just curious - aren't the RM50 and Mod50 virtually identical under the hood as far as the circuit goes? If so, couldn't you mod an RM50 to house a MIDI switching system then?
Jaded Faith
Post by Jaded Faith » Thu Jun 28, 2018 6:10 am
The difference in the RM100/MOD50/MOD100/M4/RM4 and the RM50 is the lack of MIDI implementation. While it's theoretically possible to modify the RM50 for dual module channel switching, it's not simple. It would require a lot of R&D time, some type of 3rd party micro controller or programmed IC and not be cheap. For what you gain, the cost would make it a moot endeavor.
The dual channel modules aren't truly dual channels at all. They simply use relays to provide two different gain and volume settings. They share the same signal path for both channels. For what a used MOD 50 goes for these days it's a far more economical decision that trying to upgrade an RM50. Not everything that's possible is feasible.
www.jadedfaithmods.com
https://www.facebook.com/JadedFaithMods
Email: info@jadedfaithmods.com
Authorized Service Center for US Music and Egnater
Authorized Reseller for Celestion, Scumback & Mercury Magnetics
tnjazz
Post by tnjazz » Thu Jun 28, 2018 6:22 am
Thanks Rob!
I guess I assumed that since the designs were so similar in the other products that maybe that functionality was still a part of the RM50's general build, just not wired in somehow. Just seemed odd to me that all the other Randalls and Egnaters seemed almost exactly the same under the hood and this one doesn't match up with its counterpart, which does have the MIDI channel switching.
Jaded Faith
Post by Jaded Faith » Thu Jun 28, 2018 10:11 am
My pleasure. Your line of thought is quite logical. I wish it was true and that simple myself. The RM50 is my favorite amp int he line and I'd be happily upgrading them if it was easy and cost-effective. I grabbed a MOD50 personally and it was far easier.
