how to use a RM22 in large venues?
Discussion for both Egnater & Randall modular amps
Felipe R
Post by Felipe R » Thu Feb 25, 2010 8:31 am
im interested in this head mostly cuz the boost funcion, but sadly it do not have slave out like other mts heads for use in large venues.
its posible to mod for a slave out to use with my poweramps?
VitaminG
Post by VitaminG » Thu Feb 25, 2010 8:41 am
mic it into the PA?
Felipe R
Post by Felipe R » Thu Feb 25, 2010 8:50 am
VitaminG wrote:mic it into the PA?
not a fan of speaker emulation tones, and i prefer a 4x12 moving air.
Nightdare
Post by Nightdare » Thu Feb 25, 2010 10:40 am
Rewind!
Since when is 'micing a speaker' emulating?
also, since when can't you hook up the 22 to a 4x12?
m0jo
Post by m0jo » Thu Feb 25, 2010 1:27 pm
Why don't you ust get an RM4 to use with your poweramps?
You can just put 2 extra modules in for the boost sounds.
Salvation Mods Twinface, Mash-all+, Sloogie, Mu?eca, Shiver (Facelift), modded XTC, stock Recto
Randall RM4 - Randall RT2/50 - Randall RM22
TT-Cabs REX V212
www.sparkplugmusic.nl
crankyrayhanky
Post by crankyrayhanky » Thu Feb 25, 2010 1:34 pm
the boost in the rm20 is different than other amps...it adds a natural tube compressed feel that is awesome for leads. I would love to that have that option on the other amps...or perhaps there's a pedal that can do this smooth/gain compressed vibe?
lol, I just told someone else no to compressors...
m0jo
Post by m0jo » Thu Feb 25, 2010 1:50 pm
lol yeah I do know what you feel.
I'd guess it's the same effect as when you have any high gain module and turn the gain from 9 o clock to full out?
It doesn't add audible gain, just compression. :)
TT-Cabs REX V212
Felipe R
Post by Felipe R » Thu Feb 25, 2010 2:13 pm
Nightdare wrote:Rewind!
a 18w poweramp is cool for practice, small blues gigs but can not sound like a 100w poweramp into a 4x12 cab in a metal gig
m0jo wrote:Why don't you ust get an RM4 to use with your poweramps?
Had the Egnater M4 and i didn like the feel, no punch like other preamps imo
crankyrayhanky wrote:the boost in the rm20 is different than other amps...it adds a natural tube compressed feel that is awesome for leads.
that the point, i like the boost in rm20 also
deadcat
Post by deadcat » Thu Feb 25, 2010 9:57 pm
Every large metal show I've been to the crowd (and I) were listening to the house p.a., not the miked cabs onstage. A sweet fifteen watt combo will sound just as big to a crowd when miked as a 412 with a larger power amp. A 22 watt amp should also still put enough db out to jam with a drummer, just because an amp can go louder than this doesn't mean it should.
In m.h.o. I'd say a 412 will get all the air you need with a 22 watt amp for jamming.
*RM50LB - TAD6L6GC *SUPER CLEAN *XMG+ *ISP 212 POWERED EXTENSION CABINET
crankyrayhanky
Post by crankyrayhanky » Thu Feb 25, 2010 10:03 pm
I measured the rm20 volume at one point, it puts out about 88dbs, add another 8-10 with the boost
Me playing the drums by myself is about 85dbs, so I guess if the dummer gets excoted and starts hitting hard, it will make the rm20 not quite enough. Depends on the situation....most bar/clubs won't want you to go beyond 85 anyway, so it would work, but ...there's no room for helping yourself if you're buried in the mix
crankyrayhanky
Post by crankyrayhanky » Thu Feb 25, 2010 10:22 pm
Just to follow up, I used to use an Orange Tiny Terror 15 watter and it had plenty; I remember that band being loud too. I think part of the watts in the rm20 are built into the boost feature. 85dbs is just not enough, I can talk loudly and hear myself easily...Of course 85 is more than enough to annoy sleeping family members
severedmetal
Post by severedmetal » Fri Feb 26, 2010 2:31 am
if you want to get technical a 100watt power amp section is between 6 and 9 decibels louder than 20 watt power section.
fun little fact. doubling the wattage gives a 3db increase in volume.
also lower stage volumes will allow your sound engineer to have much better control over the live mix. and you may even be able to hear the drummer :D
RM100 (Custom 3, Mr Scary, Ultra, Treadplate)
Krank Rev Cab (V30's and V12's X Pattern)
Schecter C1 Blackjack
galao
Post by galao » Fri Feb 26, 2010 4:41 am
right, 100 watts are just twice as loud as 10 watts. mostly the wattage printed on your amp hasn`t got anything in common with the "real" wattage. there are a few 100w marshalls that have under 50 watts.
if you play in a band the subjective loudness of an amp basically depends on the eq-settings and the qualtity of your equipment (guitar, pickups and speakers). if the sound is "muddy" or midscooped it will always be difficult to hear what you`re playing, even at high volumes.
DUAL CHANNEL MODS
https://yuneo.de
lolthrash
Post by lolthrash » Fri Feb 26, 2010 9:09 am
this thread is really confusing.. i don't understand why you can't just run it into a cab of ANY kind/size and stick a microphone in front of one of the speakers running straight into the PA....? like every other show ever that isn't a basement or someones living room
ENGL Ritchie Blackmore
Randall 4x12 w/ G12T-75s/V30s in X-Pattern
Jackson Dinky DK2 w/ JB/Jazz
Epi Les Paul Custom w/ Gibson 498T/490R
yigba
Post by yigba » Fri Feb 26, 2010 9:30 am
I agree with lolthrash. If you need more volume for yourself just put a little of it thru the monitors.
