Need help diagnosing.
I 1st put the Grail in slot 1 of my RM4. I barely had any sound even when I cranked the Level on the module. The other 3 modules worked just fine as they should.
I decided to switch the Grail to a different slot to see if maybe that was it. I moved it to slot 4 of the RM4 & moved that module to slot 1. Now the Grail has no sound until the Level on the module is at about 9 or so (5 o'clock+). So then it was either no volume or blasted. I haven't done any other tinkering since then.
Before I put it in the RM4 the tube in V2 was not in the socket & the tube in V1 was not seated all the way. I inserted the V2 tube & seated the V1 tube all the way in the socket.
Any thoughts on possible issues/causes... bad tube(s), loose connection, bad pot, maybe it needs to completely warm up to room temperature 1st. It was sitting on my front step when I got home from work. I had it sitting out for about 15 minutes on the counter prior to putting it in the RM4.
From what I can tell I think I am going to dig this module. If I can get the level issue resolved.
