Cornford
funny you should mention it
I've been rocking out to my new AMT C2 pedal just this past week
killer tones !!
http://www.youtube.com/watch?v=SUr2B_FisvQ
I'm always listening/watching!
I would think that a lot of people are hesitant to run pedals for their dirt because they feel they need the tubes. I always preferred tube amps BUT I haven't tried a lot of the newer pedals and you are right, there is some very convincing stuff out there.
As for those AMT pedals, I thought their intended purpose was to be run through the loop using the output stage of the amp rather than going through the front end or front of a module. They make a line of pedals for out front as well but the one you listed is best in the loop.
fuzzboat said:
I don't know why more players aren't running pedals thru
their clean modules
there are some really incredible pedals out there !
Hey Kapo, if your reading this "check out kingmans P2 vid for instant EVH !!
http://www.youtube.com/watch?v=x4IF9RYsXk0
Burgs reported an audio issue with that version. Check out the 'remaster':
http://www.youtube.com/watch?v=9CLi4gA_b4M
Kapo, as explained in the video, there are 3 outputs - one for into the front of an amp, one into a poweramp, another for direct
I own both the C2 & VT2 = in front or in the loop either work Great !!
also, doesn't have to be a clean tube amp :shock:
modellers work just fine :lol:
as far as kingmans remastered P2 vid - the "reported an audio issue"
is an anomoly at best
I owmed older AMT pedals an these "legend series" are definitely a step in the right direction
VitaminG said:
their clean modules
and each output sounds a bit different tonally
plus you can use ALL 3 AT ONCE !!!!
Were they always designed with three different output options? That is design genius. Makes it perfect for a traveling musician or someone who wants to gig light and doesn't know what type of amp will be available to him.
for the record I didn't think that VH demo was remotely close. That said, I think he records a lot of pedals direct does he not? Not a bad tone for direct recording. In a band mix it would probably do just fine. Nobody cares about what tube amp you are using in a little club..
sorry to steal your Cornford thread, Ross :oops:
guess theres not alot of demand for a cornford !?!
fyi, I'll be posting some clips of my C2 & VT2 pedals soon
found a way to lose the fizz with killer results :idea:
Fine. How about a Victory module?
