Got the Judge yesterday...
Area specific for Lynch, Hammett, Donagan (1086), etc modules and amps
fuzzboat
Post by fuzzboat » Tue Mar 20, 2012 9:41 am
I luv the GTO so much - that I got 2
boost & para eq and its instant 80's metal
plus it plays well with a graphic eq too (unlike some other
modules)
I ♥ Shirley Manson
rblyn
Post by rblyn » Fri Apr 06, 2012 5:42 pm
fuzzboat wrote:I luv the GTO so much - that I got 2
modules)
Cool! I dont even boost or EQ mine...Just stock but still love it. I dont know what I was thinking but I traded mine a few months ago- Got another recently and will NOT part with this one. I've had/have what many consider the BEST modded modules and still use this module quite a bit. It's got a chewy, brown tone and feel that I keep coming back to....
RM100/GT KT88's/Winged C EL34's x 2
RM20CP
Randall XL 4x12 x2/Boss GT10
"only the best" mods!
Ulf
Post by Ulf » Fri Jul 13, 2012 9:42 am
I can recommend this mod for the judge:
http://mtsforum.grailtone.com/viewtopic.php?t=15730
Ulf
RM4, RM1250, MOD100
too many modules
notyet
Post by notyet » Wed Oct 02, 2013 9:20 am
Does anyone else find the bright switch to be semi-useless? It sounds to my ear like the cap is too big or too small. If it were bigger, it would just be a gain boost with some low end roll off. If it were smaller, it would just add some chime to the sound. As it is now, it just seems ill-sized.
rblyn
Post by rblyn » Wed Oct 30, 2013 6:51 pm
notyet wrote:Does anyone else find the bright switch to be semi-useless? It sounds to my ear like the cap is too big or too small. If it were bigger, it would just be a gain boost with some low end roll off. If it were smaller, it would just add some chime to the sound. As it is now, it just seems ill-sized.
In a way, yes...but it is pretty much the same with any of the stock mods when gain is cranked...which is where I usually have my Judge. For some reason, this one sounds best with high gain settings and thins out a bit as you back off. Ive read here on many posts that the bright switch on these stockers really looses its effect with higher gain settings though-
RM20CP
