i do it meself
That oh so special place to discuss Pete's (OKstrat) module modifications.
Moderator: okstrat
guitarmanscott65
i do it meself
Post by guitarmanscott65 » Sat Aug 07, 2010 6:17 pm
i have a blackface i dont use and i want 2 mod it myself.i would like to get a little distortion,but i dont know wich Rs and Cs to change.would anyone b so kind as to piont me n the rite direction?
you can tuna piano but you can't tune a fish
eedude
Post by eedude » Thu Sep 16, 2010 10:46 am
i suspect this is in the wrong category... Moderators is there a better place to move this to?
to get more gain look at the attenuation between 1st and 2nd stage on the module. I don't have a blackface schematic, but I'll bet it's similar to the Clean. So on the clean it's R26 and R28, check your board measure those two r's and lets see what value they are...
Good Deals w/ randall3, cold Machine, El Dangerouso, tonelover, Seano, jitterybit, alowerdeep
Prog for all: http://www.myspace.com/onyxguild
m0jo
Post by m0jo » Thu Sep 16, 2010 3:09 pm
First off you'd need to start using proper language, with this "2" and "rite" you seem like a 12 year old.
No offence meant, just constructive cristicism.
On the grailtone.com website there are some mods that are pretty well documented.
Salvation Mods Twinface, Mash-all+, Sloogie, Mu?eca, Shiver (Facelift), modded XTC, stock Recto
Randall RM4 - Randall RT2/50 - Randall RM22
TT-Cabs REX V212
www.sparkplugmusic.nl
guitarmanscott65
Post by guitarmanscott65 » Wed Sep 22, 2010 4:24 pm
27 is 2100000.....28 is 220k....so whattia think? and thanks FOUR responding you guys!I've had my rm 100 four several years now,and love it.
eedude
Post by eedude » Wed Sep 22, 2010 5:58 pm
so that's 2.1M and 220k which make one hell of an attenuator.
I would put maybe a 1M or a 470k across the 2.1M. Note that if you do that the module will get louder as well and have a little bit of a tone shift due to C10 (i would expect a little less high end).
I have no idea how 'good' this mod will sound but you will start to overdrive V2.
guitarmanscott65
Post by guitarmanscott65 » Tue Sep 28, 2010 5:02 pm
I like the idea of less treble.All my gtars have wammys,so that might be just right.thanks.i'll give it a try.
eedude
Post by eedude » Wed Sep 29, 2010 10:45 pm
guitarmanscott65 wrote:I like the idea of less treble.
.. you could even pull out c10 and see if you like that then.....
guitarmanscott65
c10
Post by guitarmanscott65 » Sat Oct 09, 2010 4:34 pm
DUDE! you nailed it with 470k.perfect on the "breakup" part of it.now, could you tell me a bit more about the funkshun of c 10 ?I'm looking for a fuller more robust sound.he he he i said bust.
eedude
Post by eedude » Sun Oct 10, 2010 5:35 pm
C10 allows high freq to bypass the attenuator. You may want to take it out and see how you like the sound.
Also for a little more poop, you can put a 1uF in for C7 (i think it not populated right now.
guitarmanscott65
nob
Post by guitarmanscott65 » Sat Oct 16, 2010 1:16 pm
just curious, is there an easy fix to get my volume nob back from 8 or 9 to about12 or 1:00?
eedude
Re: nob
Post by eedude » Sat Oct 16, 2010 5:34 pm
guitarmanscott65 wrote:just curious, is there an easy fix to get my volume nob back from 8 or 9 to about12 or 1:00?
i'm not sure i understand.... is it that with the mod you need to turn down your master to ~8 where is was at ~12 before the mod?
Shinozoku
Re: nob
Post by Shinozoku » Sun Oct 17, 2010 8:13 am
Turn it clockwise 90 degrees.
RM100M w/ Tung Sol 5881's
Blackface(self modded), Ultra Lead, SL+(out of commission), Ultra XL (self modded)
Vader 2x12 Cab
Edwards E-AL-128 with a Seymour Duncan JB
Re: nob
Post by Mattfig » Sun Oct 17, 2010 9:46 am
:lol:
guitarzan
but.....
Post by guitarzan » Mon Oct 18, 2010 5:49 pm
Which one is the any key? :P
guitarmanscott65
Re: nob
Post by guitarmanscott65 » Sun Oct 31, 2010 3:48 pm
yes
