MIDI hack
For you Bob Villa types that modify modules
Moderator: Jaded Faith
ramalhais
MIDI hack
Post by ramalhais » Tue Nov 22, 2016 7:05 pm
So i bought a used RM100 and it came without a footswitch.
I wanted to try a low cost solution and i hacked this for arduino:
https://github.com/ramalhais/code/tree/ ... k/midifoot
Hope this helps someone.
CrunchBunch
Post by CrunchBunch » Tue Nov 22, 2016 9:25 pm
What a great DIY project. Awesome stuff. Thanks so much for sharing this and documenting it so well.
MarcoR
Post by MarcoR » Wed Nov 23, 2016 12:24 pm
I was just thinking about building a simple arduino midi footswitch!
Thanks for the motivation!
Synergy: SYN2, Friedman DS, HBE
Self Modded: Egnater B'Man, SL2X
Amps: VHT 2/50/2, RM50, Landry LS100 G3, Splawn Quick Rod, Marshall 6100LM
tschrama
Post by tschrama » Wed Nov 23, 2016 1:31 pm
few years ago I made a DIY midi pedal to do this.. very simple, 2 button. Arduino is really overkill for a midi pedal. plenty of 2$ IC that can do that...
my small atelier called 's-Gravenmade | Follow me www.sgravenmade.com | Join my Amp Building Workshop 14 april 2018
Good deals with: C2ply, BenMesaBoog, YouguitarHero, nitrous12, kylendm.
tschrama
Post by tschrama » Wed Nov 23, 2016 1:45 pm
I used this one:
http://www.picaxe.com/Hardware/Starter- ... rter-Pack/
but if you are handy, this is the actualy IC:
http://www.picaxe.com/Hardware/PICAXE-C ... ontroller/
IIRC it only took 8 lines of code... litterally 8 lines!
VitaminG
Post by VitaminG » Wed Nov 23, 2016 6:13 pm
nice. What are you housing it in? Are you adding a 3rd switch for the RM100?
tschrama
Post by tschrama » Thu Nov 24, 2016 5:22 am
For Housing I used a metal stompbox housing. It only has two buttons, channel down and channel up. That's all.
If ur interested, I can send you a picture via email.
grtz,
Thijs
CrazyNutz
Re: MIDI hack
Post by CrazyNutz » Thu Nov 24, 2016 8:29 am
Nice work. I was in the same situation, I bought a used RM100 no foot switch.
I was actually planning to do the same thing as I have several arduinos laying around, I lucked out and found a new in box rf3 footswitch for $50 on ebay.
ramalhais wrote:So i bought a used RM100 and it came without a footswitch.
ramalhais
Post by ramalhais » Thu Nov 24, 2016 4:26 pm
tschrama wrote:few years ago I made a DIY midi pedal to do this.. very simple, 2 button. Arduino is really overkill for a midi pedal. plenty of 2$ IC that can do that...
You're right it's overkill.
Anyway it costs 2.5EUR, it's easy to program, easy to upload with a USB cable, easy to update and you can extend with LCD display, etc.
I also had several laying around and ready to use ;)
ramalhais
Post by ramalhais » Thu Nov 24, 2016 4:28 pm
tschrama wrote:I used this one:
Can you share that code? You got me intrigued.
ramalhais
Post by ramalhais » Thu Nov 24, 2016 4:32 pm
VitaminG wrote:nice. What are you housing it in? Are you adding a 3rd switch for the RM100?
No housing yet, but my plan is to use 2 normal guitar footswitches with 2 switches each and connect them to the arduino with stereo female jacks.
So it would be like a converter from footswitches to MIDI.
I'm going to try to fit it inside this box of cigarillos:
ramalhais
Post by ramalhais » Thu Nov 24, 2016 4:33 pm
tschrama wrote:For Housing I used a metal stompbox housing. It only has two buttons, channel down and channel up. That's all.
grtz,
Thijs
Can you post it here? That would be great! Thanks!
ramalhais
Re: MIDI hack
Post by ramalhais » Thu Nov 24, 2016 4:36 pm
CrazyNutz wrote:Nice work. I was in the same situation, I bought a used RM100 no foot switch.
Lucky guy! This needs some polishing but thanks!
I saw one for 50EUR on ebay and let it fly away :(
Anyway this is also fun.
tschrama
Post by tschrama » Thu Nov 24, 2016 4:46 pm
`The Midi Pedal
`PICAXE 08M2
#no_data
init:
setfreq M16 `set internal 16MHZ speed
symbol serial_out = c.0
symbol serial_in = pinc.1
symbol led = c.2
symbol button1 = pinc.3
symbol button2 = pinc.4
symbol midch = b11
symbol button_on = b12
symbol pc_statusbyte = b13
symbol program = b14
program = 1
midch = 0
pc_statusbyte = 144 + midch
hsersetup b31250_16,%00010000
main:
if button1 = 1 then
if button_on = 0 then
high led
program = program + 1
hserout 0,(pc_statusbyte,program)
end if
end if
if button2 = 1 then
low led
program = program - 1
end if
end if
goto main
tschrama
Post by tschrama » Thu Nov 24, 2016 4:51 pm
' The Midi Pedal
' PICAXE 08M2
' buttun1 = Program Change to next program, button2 = PC to previous program
' met fast forward functie if button id pressed lomger than 1000ms
symbol program = b13
program = 0
hsersetup b31250_4,%00010000
'BUTTON pin,downstate,delay,rate,bytevariable,targetstate,address
myloop: button c.3,1,100,10,b1,1,pushed1
button c.4,1,100,10,b2,1,pushed2
pause 10
goto myloop
pushed1: program = program - 1
if program > 99 then
program = 99
endif
hserout 0,(192,program)
goto myloop
pushed2: program = program + 1
program = 0
endif
goto myloop
