Syn 1 volume drop
rickgk
Syn 1 volume drop
Post by rickgk » Sun May 12, 2019 1:40 am
Hi,
I was using my syn 1 today and all a sudden the volume dropped drastically.
I've checked my cables, and tried all of my modules.
I notice slightly more volume on channel 1 but it's nowhere near what it was or should be.
I've tested in four different amp returns, and also directly into my Fryette Powerstation line in as a Poweramp.
Any ideas?
Kriig
Re: Syn 1 volume drop
Post by Kriig » Sun May 12, 2019 4:05 am
Have you checked the tubes?
rickgk
Post by rickgk » Mon May 13, 2019 4:14 am
The single tube in the syn 1 itself? I did the chopstick tap test and it didn’t pop or crackle, I guess it’s possible it has died, but it looks ok.
I tried all three of my modules and they all had the same problem so I doubt it’s an issue with the modules.
Kriig
Post by Kriig » Tue May 14, 2019 1:40 am
Try to switch the tubes on the SYN1, just to rule that out.
If those are ok, i would shoot a mail to Synergy. They are usually very responsive.
ChrisB
Post by ChrisB » Tue May 14, 2019 4:54 am
I have one of the original SYN 1's that I got directly from Synergy and I had a similar situation where my SYN 1 would cut out. I sent it to Synergy for repair and it is great now. I would also recommend contacting Synergy.
