I was wondering the exact same thing.
Back in the days, I had a rig build around a 6L6 VHT poweramp (Ltd edition Black Beauty 2/56/2), Triaxis on the left channel, and JMP1 on the right channel, running both at the same time. Perfect match! But it was a pain in the *** to setup and MIDI program, and even a greater pain to carry that huge rack around.
I finally kept the Triaxis, which was a better match for the 6L6 power section.
Being the preamp freak that I am, that Synergy stuff look very promising to me.
And I was wondering if it would be possible to have two different modules at the same time, one on the left, the other on the right.
Imagine a SLO and VH4 in stereo! :shock:
But if the only way to achieve that is to use two SYN1 or two SYN2, it wouldn’t be the best solution.
By the way, is it possible to use the SYN2 with only one module, and to let the second slot empty? It would be a 2U preamp, which would be a bearable solution, though still crazy expensive...?
