Syn1/2 Question
isolated1523
West Liberty, KY
Pretty sure the answer is no, and I may have asked this in a thread a year or 2 ago but can't find it. Do either the SYN1 or SYN2 have a built in "clean"?
I guess I wondered if, when the preamp module is "bypassed", the signal was still routed through the XLR and cab emulation, therefore resulting in a useable "clean" signal?
When you bypass the preamp the XLR out would be muted.
But the clean signal will go through the "to amp in" output.
Gotcha. In that case, it wouldn't be much use direct to FOH in that way then. I was hoping for a way to basically make it "3" "channels". No biggie, other ways to work it.
Surely you can just patch “to amp input” to “from amp fx send”. Just your levels will be off. Maybe patch in a clean boost or something?
