Recommend a low wattage Poweramp for Syn-1
Area for the Synergy line of amps and modules
AdInfinitum
Post by AdInfinitum » Mon Mar 04, 2019 3:18 pm
I want to use the Syn-1 with an Ox and don't want to run it through an FX Loop of a tube amp. Something small for bedroom use.
cmsaub
Re: Recommend a low wattage Poweramp for Syn-1
Post by cmsaub » Tue Apr 30, 2019 12:29 pm
I'd be curious to learn this as well
blackstratblues
Post by blackstratblues » Wed May 01, 2019 4:22 am
The Fryette Power Station would work well as a power amp.
zombieskank
Post by zombieskank » Wed May 01, 2019 10:53 am
I use a mesa 50/50 that has a low wattage switch that drops it down to 15 watts. Or one of those 200$ monoprice tube amps on the 1watt setting into the fx loop, but you said you didnt want to do that. It sounds pretty mean at low volume though!
