Do The Synergy Modules Fit?
G-Man Music
S.F. Bay Area
I've read on the GEAR PAGE a while back that the Synergy modules don't fit in the Egnater Mod 50. Some clearance issues in one of the slots. Can someone confirm this?
In the first slot they can push against a connector at the back because the PCB is cut more shallowly on the back edge than the Randall and Egnater modules. It will still fit but could exert pressure on the connector and possibly cause failure in the long run. Or not.
They fit just fine in the second module slot with no issues at all though, so there’s that.
I may have an older mod50 but a Synergy module will not fit at all in the left slot. There’s a vertical metal bar in the way. The right slot is no problem.
