FX loops on Syn1 and Randall Rm100
hmic10
I am running my Syn1 through the RM100, in the effects loop, my question is I want to put a rack unit in the other loop of the RM100,
I have done it but is just doesn't sound right? Can both effects loops work at the same time?
Thanks
HMK
Read the SYN1 manual about 4 Cable Method (4CM) - connect it to the Series loop on the RM100, that will let you run your rack effects unit into the loop of the SYN1 & it will allow bypassing the SYN1 & having the rack effects also work in the loop of the RM100.
