New Issue with my SYN1
Lespauled
Staff member
I'm having an issue with my Syn1 lately. It seems like it doesn't like the red channel on startup. It happens with any Synergy module. When I switch to the blue channel, it works. When I switch to the red, no sound. After switching back and forth a few times (via the foot switch), the red channel eventually comes on.
Any ideas where I should begin to diagnose this problem?
Thanks
Does it act the same way using the button on the syn1?
You probably tried that, but if it acts the same, that would eliminate a problem with the footswitch.
Thanks, but unfortunately, same result. One thing checked off :) Thanks again.
If you are the original owner and it is still under warranty, you may need to send it back to synergy.
I guess you have considered this already.
I’m not an expert, but it may be something other than an easy fix like a tube. Might be a switching relay or something deep like that.
Thanks. I’ll have to look into the warranty, when I bought it, etc.
