As a follow-up to myself, the SYN-30 is NOT self-biasing. B.A.D. reached out to me with the following info:
"You need to rebias unless you use tubes with same numbers (if you use matching tubes using the numbers on top you shouldn't have to re-bias). The proper bias is 35mA"
Just posting in case it helps someone else out as well.
