Syn 50 midi switching?
richantonelli
Hi all
Just got the Syn 50 amp with a couple of Friedman modules. Sick stuff!
I’m having trouble getting the channels to switch with midi via a boss ms-3. The included footswitch works but I’m not going to be using that to avoid tap dancing.
Anyone know how to make this work? I’ve tried what the manual says but it’s not very clear. Also can’t find any videos at all in this subject. Any help is appreciated!
Since the stock Synergy footswitch works, then MIDI is definitely working on the head (and that proves the cable is good). Refer to the SYN50 manual for dipswitch positions /MIDI channel assignment, I suspect you don't have the MS-3 programmed properly, but I'm not a guru about MIDI & don't own a MS-3, so can't offer any more help. Good luck -
